Burns Built Posted December 6, 2016 Share Posted December 6, 2016 We are trying to change the timing belt on our Son's 1996 Subaru Impreza, but we cannot get it to time correctly. The engine is 2.2 liter SOHC. The marks appear to be in good position, but it will not time and run. I think he might have the crank position wrong. How do you put the crank in right position with out the belt on I need TDC 2 Quote Link to comment Share on other sites More sharing options...
wtdash Posted December 6, 2016 Share Posted December 6, 2016 Hi and welcome, Try this: http://legacycentral.org/library/literature/timing/1.htm Sounds like you've got your alignment marks....not aligned. TD Quote Link to comment Share on other sites More sharing options...
lmdew Posted December 10, 2016 Share Posted December 10, 2016 With the timing belt off you can rotate the cams so the valves are closed and then put the crank front belt pulley on and turn it with the bolt. The passenger side cam is free when the alignment mark is up, so those valves are closed The Drivers side cam is under spring pressure from the valves being open. You can rotate it about a 1/4 turn clockwise with a 17mm wrench on the cam sprocket bolt to close the valves. Once the crank is set, just rotate it back to the alignment mark. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 10, 2016 Share Posted December 10, 2016 Using the wrong crank mark is common problem. 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 11, 2016 Share Posted December 11, 2016 ^^^ yep, it's the dash mark on the tab at the rear of the crank sprocket - NOT the arrow/triangle. you do NOT want TDC (for belt installation), you want the pistons at their half-way positions. Quote Link to comment Share on other sites More sharing options...
ericnsmith1 Posted December 31, 2016 Share Posted December 31, 2016 1 Lucky Texan is right again! I've just been through this with a '98 EJ22 someone had transplanted into my '98 Legacy Outback a couple of days ago. I don't know what the arrow on the crank pulley is for- but do not use that as your alignment mark! Look for the grooved line on the back flange of the crankshaft pulley and use that. When I pulled my belt & realigned the crankshaft pulley to the correct mark- after putting it all back together, the engine,(which had not been started for 14 or 15 months fired up immediately on the first try! Another point of reference: when you have the two camshaft sprockets and crankshaft sprocket all properly aligned (at 12:00 straight up) before installing the belt, you will notice that if you turn the arrow on the Right camshaft sprocket to the notch in the inner timing cover, the #1 piston will be at TDC on the ignition stroke. Do not leave the Right camshaft in his position, however! Align the little line on the rim of the camshaft sprocket with the little notch on the inner timing belt cover. Same on the left side. Be sure to use the grooved line and not the arrows to align the camshaft sprockets! Quote Link to comment Share on other sites More sharing options...
