Ea82 glass sunroof... can it be removed & replaced?
perhaps with a regular solid panel sunroof? If it's possible what's the difficulty level like. I'm just not a big fan of glass is all... burns my poor melon :(
If the swap canno't be completed, does the glass roof at least have a fabric cover that one can slide underneath? tia
-Rob
hi there. yes, the glass is removeable. there are two black plastic panels with the obnoxious plastic screws. the sunroof can be unbolted after those trims are removed. there is supposed to be a sliding cover that goes under the glass inside the car. I'd suggest that you have your sunroof tinted limo black. that will be cheaper than having something else made to replace it, since your slider panel is, by the sound of it, missing. you shouldn't need to take the glass out to have it tinted, and it shouldn't cost more than $10-$20.
either the glass itself will swap, or the whole unit as an assembly will swap also.
there are shims that adjust how the window fits in its seal. the only case of a leeky 'roof is when it wouldnt close all the way. but that is why there are shims
