Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Remove & install evaporator in a MY00 impreza?
#1
Posted 13 June 2004 - 05:48 AM
Im brand new here, living in sweden.
I have a impreza GT, with no AC.
I have bought a system, so I can mount it in my car.
The question is, how do you remove the evaporator in the car?
I know it´s placed in the passenger side of the car, in the heat exchanger under the glovbox.
How do i get it out?
Has anyone done this, and have some pictures or some kind of instruction how to refitt an whole AC system?
Thanx.
//Jimmy
#2
Posted 13 June 2004 - 02:20 PM
The glovebox needs to come out, to begin with. (Two screws in the hinge at the bottom) Only if you are lucky will you be able to work from there without taking out a whole bunch of other stuff. The heat exchanger is connected to engine coolant system inside the engine bay, on the "firewall".
I would strongly recommend finding a Subaru manual before you start this project. It will save you a lot of trouble if you know exactly what you are doing.
#3
Posted 13 June 2004 - 02:37 PM
There is not a plastic thing that I can remove, and then take out the evaporator?
Can I see something through the fan hole maybe?
I´m a porsche engineer, so I can repair and so on cars.
I just need some help to localize the evaporator and tak it out and mount it in my car.
(the guy I bought it from have not taken out the evaporator, so I have to do that as well)
#4
Posted 14 June 2004 - 08:17 AM
#5
Posted 14 June 2004 - 11:03 AM
to get the evap out, just take the glove box out, and you should see the evap box right behind it. on the first gen legacies there's 2 bolts holding it in place. Once the lines are removed from the a/c system under the hood the box should just pull right out. and no you don't need to remove the heat exchanger to get the evap out.
OK, I think I got it now.
Took down the glove box, and looked behind it.
The heat exchanger is white, the evap box is black with the blower and the recycle flaps monted on.
The hole box is mounted with 4 screws I think.
I can see where the black and white box are put togheter, with some kind of sealing.
I hope it´s easy to take it out!
#6
Posted 15 June 2004 - 12:23 AM
