cartwright Posted January 9, 2017 Share Posted January 9, 2017 New member and new Subaru owner here. The engine has started to make a knocking noise, it sounds ok during warm up but gets loud with the knock when rpm's raise. I have changed the plugs and checked the timing belt cam positions which was good. I found that when I put a timing light on the plug wires, that #2 and 3 wires strobe at at much lower speed and intensity and will pause intermittently. I'm going to swap cables tomorrow to see if problem follows the wires If problem is coming from opposite sides of the coil does that rule the coil as being faulty? Any other suggestions? Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 9, 2017 Share Posted January 9, 2017 If a cylinder is not firing, it will cause low power, usually not a knock. Rod bearing starting to go out, it sounds like. 1 Quote Link to comment Share on other sites More sharing options...
wtdash Posted January 9, 2017 Share Posted January 9, 2017 Hi and Welcome, Also - post your year (Phase 1 - '90-'98 EJ22 or Phase 2 - '99-01 EJ22) and mileage...maybe maintenance history? Oil changes? Td Quote Link to comment Share on other sites More sharing options...
