subawoohoo Posted June 13, 2004 Share Posted June 13, 2004 a few weeks ago my tranny was leaking out of the shift rod seal., well it still is. anyway, i drove the car a few miles, parked it and noticed a puddle (tranny fluid) under the inner, passenger side cv joint. i replaced the seal, and about 6-10 miles later, its leaking again. something worn out? time for a new tranny? im gettin kinda irritated as i dont want to go get another tranny, or have to tear this one down. help or advise would be helpful. thanks, btw its an '80 hatch. ea71 4 spd single range 4wd. tyler j Quote Link to comment Share on other sites More sharing options...
Will Smith Posted June 14, 2004 Share Posted June 14, 2004 if the seal is retained by a screw-in cup the cup may not be in all the way; is the output shaft loose? Also important to note the seals are directional, ie. there is a left and right side. If you get the sides mixed up it will actually push oil out of the seal, although it should not be too much. Quote Link to comment Share on other sites More sharing options...
