BuffDriver Posted January 21, 2017 Share Posted January 21, 2017 My '05 Outback sometimes bucks/stumbles on low speed acceleration (lower rpms.) Especially noticeable after long downhills. Soob dealer has mentioned valve body. Any ideas? I've got 165K on the clock, regular service, just flushed the tranny. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 21, 2017 Share Posted January 21, 2017 How long since it had a tune-up? Spark plugs? O2 sensors original? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted January 21, 2017 Share Posted January 21, 2017 (edited) CEL on? if so, post the codes here. you might try disconnecting the neg battery termin al for 'a while' (overnight might b e convenient) then, test the car after reconnecting. that should reset the TCU and, if you notice much better or much worse behavior - perhaps a trans problem is the culprit. did the dealer say WHY they suspect a valve body? some folks have done transmission fluid changes and experienced better trans performance - mostly with delayed engagement however. I THINK you cars has the 5EAT trans? if so, it need s the Subaru ATF-HP fluid. Edited January 21, 2017 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
BuffDriver Posted January 21, 2017 Author Share Posted January 21, 2017 Thanks for the tips guys. Spark plugs have been in ahile. Both O2 and Fuel/Air sensors were changed ~7,000 miles ago along with the PCV valve. I do have a CEL, but it's a P0420. Just had a transmission flush by the dealer with Subaru fluid. No reasons given regarding the valve body issue. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted January 22, 2017 Share Posted January 22, 2017 My 2005 Baja had been bucking on acceleration if I got on it too hard. New plugs and wires fixed it in my case. I did the tube seals too so the oil would not eat the new wires. I used all OEM parts. Quote Link to comment Share on other sites More sharing options...
