EA 82 F.I. fuel line rubber hose bracket mounting location?
Hi Guys,
Chasing a vacuum and coolant leak and have removed and replaced the intake manifold gaskets and loads of other work since I found so many issues while moving everything around. So the bracket that the rubber fuel and I believe a vacuum line that run between the area near the driver area to the injector. There is a bracket that supports the hoses that was not attached when I pulled everything apart. Now that I am assembling I would like to attach the bracket back but am not sure where it bolts to. The only thing that seems reasonable in the intake manifold long bolts which doesn't seem right. I have scoured manuals, pics and videos. any body know where this thing bolts? it appears to only have one bolt hole. Anybody point me in the right direction?
Thanks!
