engine oil leaks - 2004 WRX 67K miles
Hi subies,
Found what looked like a small oil leak on top of my 2004 WRX's engine. Little bit oif oil pooled on engine top, both sides. I noticed a burning oil smell when driving and coming to a stop. Subaru dealer originally said it was rocker cover gaskets. But today, 3 weeks later, dealer says he'd have to do $2,000 worth of work just to find sources of leaks, including the valve covers, timing cover, seals intake manifold. He thought he saw oil leaking from those areas. And any leak repairs would add to the $2,000. I said I'd think about it. Another service writer at same dealership said he would just add some dye to the oil, then check engine a litttle later to see where the oil is leaking from. Much cheaper. I like my car and want to keep it. Anyone ever have an oil leak like this? Just looking for ssome advice at this point.  Thanks.
Even if it is valve covers gaskets that's dripping on the exhaust, each bank can be done in an hour if you know what your doing.
Did them on my car Baja turbo, and my buddy 03 WRX.
Definitely not 2,000$ worth. And I work in Cromwell CT. Which is pretty pricey town. And no way would that be a 2,000$ job to do.
But then again. If it's the head gaskets leaking oil. That's a completely different story. But I don't see how they can't find the source of the leak. That's BS. You shouldn't need to spend 2000$ on exploratory surgery on your car.
  • Like 1
