Changing 4x4 front wheel drive to rear wheel drive only
outlawsubaru1984
U could keep the 4wd tranny and just take out the front drive cv axles and put it in 4wd and now you have 2wd to the rear. I had that happen, I busted an axle and I thought the tranny was out, put it in 4wd and got home. Went to the tranny shop thinking the tranny was garbage and it was only a broken cv axle. It would save you a bunch of time and money.
Does anyone know what type of rear wheel drive manual transmission will fit a 1984 Subaru DL 4x4 wagon
Need more information.
There's nothing that's a direct, bolt-in.
There are probably hundreds of options with enough fabrication......
  • Like 1
Install a 4WD trans
Disassemble front axles and leave outer CV joints in hubs
keep it in 4WD.
You now have RWD.
best to research and see whats been done before. I seem to recall there's an EA82 car out there that's RWD.
Subaru has never offered a RWD vehicle in the use - not at least in an EA/ER and newer mainstream vehicle.
Install a 4WD trans
keep it in 4WD.
You now have RWD.
Correct. This was a custom job. I'll see if I can find it.
