daddycoolj Posted March 16, 2017 Share Posted March 16, 2017 I have a 2002 Forester that I drove home and parked last night, with no issues. This morning I got in, started it up, let off the parking brake, pushed in the clutch to roll down the driveway, and it wouldn't move. I then put it reverse, let out the clutch, and it stalled. I started it back up and tried again,and got the same result. Now it is stuck in reverse. The shifter won't budge. Does anyone have an idea what to do? Quote Link to comment Share on other sites More sharing options...
GreaseMonkey03 Posted March 16, 2017 Share Posted March 16, 2017 Does the clutch have pressure? What happens if you try to double clutch and move the shifter with the car off? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 16, 2017 Share Posted March 16, 2017 Could be the parking brake is frozen. GD Quote Link to comment Share on other sites More sharing options...
GreaseMonkey03 Posted March 16, 2017 Share Posted March 16, 2017 Shifter won't budge though. Maybe linkage is binding? Quote Link to comment Share on other sites More sharing options...
daddycoolj Posted March 16, 2017 Author Share Posted March 16, 2017 Does the clutch have pressure? What happens if you try to double clutch and move the shifter with the car off? The clutch has pressure. I tried to move the shifter with the car running, and not. Quote Link to comment Share on other sites More sharing options...
daddycoolj Posted March 16, 2017 Author Share Posted March 16, 2017 Shifter won't budge though. Maybe linkage is binding? That could be. I was scrambling to get to work ,so i haven,t been under the car. Quote Link to comment Share on other sites More sharing options...
daddycoolj Posted March 16, 2017 Author Share Posted March 16, 2017 That could be. I was scrambling to get to work ,so i haven,t been under the car. I don't get why the car wont move. 1 Quote Link to comment Share on other sites More sharing options...
Dj7291993 Posted March 17, 2017 Share Posted March 17, 2017 I'd jack up the rear, see if it feels like the parking brake is stuck, or if you have a little bit of movement, indicating a problem in the drive-line. I'd also be looking a the linkage. If it somehow didn't release from a forward gear before going into reverse, the torque on it might have let it bind on itself and lock up. One thing you could try is to put a socket on the crank and slowly try to turn it backwards while someone is trying to pull it out of reverse. If it comes out that way, I'd leave it in N, start it up, and let out the clutch. If it tries to take off, you know one of the forward gears is still engaged. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 17, 2017 Share Posted March 17, 2017 Was it below freezing this morning? Have you tried moving it since then? Quote Link to comment Share on other sites More sharing options...
daddycoolj Posted March 17, 2017 Author Share Posted March 17, 2017 It was below freezing, and yes I tried it once it warmed up. Still no luck. I haven't tried turning the crank. I'll do that tomorrow. Thanks Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 17, 2017 Share Posted March 17, 2017 Try rocking the car back and forth a bunch of times, then try popping it out of gear. You can also try popping the clutch out with it running while pushing against the shifter. If you can't get the car to move ANY at all it's because the parking brake is stuck. Sometimes the cables freeze if they get moisture in them. Even with it in gear, the car should roll back and forth a little bit if the brake is off. It's not easy for a transmission to get stuck in two gears at the same time. The linkage inside is designed to prevent that, so it's unlikely for it to happen. Quote Link to comment Share on other sites More sharing options...
daddycoolj Posted March 18, 2017 Author Share Posted March 18, 2017 Try rocking the car back and forth a bunch of times, then try popping it out of gear. You can also try popping the clutch out with it running while pushing against the shifter. If you can't get the car to move ANY at all it's because the parking brake is stuck. Sometimes the cables freeze if they get moisture in them. Even with it in gear, the car should roll back and forth a little bit if the brake is off. It's not easy for a transmission to get stuck in two gears at the same time. The linkage inside is designed to prevent that, so it's unlikely for it to happen. Once I got some help, we were able to move the car uphill a few inches, and relieve the pressure to get it out of gear.it's all good now. I'm still puzzled as to why it wouldn't roll when the clutch wasn't engaged. Quote Link to comment Share on other sites More sharing options...
daddycoolj Posted March 18, 2017 Author Share Posted March 18, 2017 Once I got some help, we were able to move the car uphill a few inches,and relieve the pressure to get it out of gear.it's all good now. I'm still puzzled as to why it wouldn't roll when the clutch wasn't engaged Quote Link to comment Share on other sites More sharing options...
1997reduxe Posted March 18, 2017 Share Posted March 18, 2017 i am just learning but theres also another brake on the manual trans? that may have been stuck also? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 18, 2017 Share Posted March 18, 2017 Not on an 02. They stopped the hill holder around 98. Quote Link to comment Share on other sites More sharing options...
