lorigar Posted March 18, 2017 Share Posted March 18, 2017 I have a 2012 Impreza hatch. The check engine light came on and that is the diagnostic code. The car had its engine block replaced with the previous owner and the warranty only covered what was replaced. Here's the description of the what they replaced "removed engine unit and disassembled. Checked cylinder heads and verified good. Replaced short block with new block and reassembled." The warrently only coveres what they replaced and if we have to replace the oil control valve. Would that be under the warranty or outside of it? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 18, 2017 Share Posted March 18, 2017 could be as simple as a poorly re-connected wiring harness. Quote Link to comment Share on other sites More sharing options...
Stevo F Posted March 18, 2017 Share Posted March 18, 2017 This is a common issue with late model Impreza's. My 2014 had this replaced under factory. I assume your original warranty has expired. I'm under the 6 Year/100K mile warranty with mine now and wonder if it would still be covered. Not sure how expensive part it is. Quote Link to comment Share on other sites More sharing options...
lorigar Posted March 18, 2017 Author Share Posted March 18, 2017 Thanks for the replies. Because the short block was replaced, that part of the engine is under a 1 year, 12,000 mile warranty. I don't know enough about cars to know if the OCV would be covered as part of the short block replacement, or if the OCV is part of the engine that they describe when they say they disassembled the engine. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 18, 2017 Share Posted March 18, 2017 Not likely. The OCV is on the cylinder head and it isn't necessary to remove it to remove the head from the block. Check the connector on the solenoid. (Try google for pics of the location) Quote Link to comment Share on other sites More sharing options...
