Lockett77 Posted March 26, 2017 Share Posted March 26, 2017 My engine locked up on my awhile back so i put new piston rings and new headgaskets on got everything put back together and my left (drivers side) intake camshaft won't line up to its mark it keeps hitting the #2 cylinder. All the other camshafts line up to where they're supposed to. No i didn't mix up camshafts and no valves are bent. What's going on? Quote Link to comment Share on other sites More sharing options...
DaveT Posted March 26, 2017 Share Posted March 26, 2017 Im not sure what engine you are working on, this may matter. Is it possible that you have to move the crank so that no pistons are at TDC to set the camshaft position, and then, one that is done, put the crank back into position for the belt install? Quote Link to comment Share on other sites More sharing options...
Naked Buell Posted March 26, 2017 Share Posted March 26, 2017 Yeah, what engine are we working on here? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 26, 2017 Share Posted March 26, 2017 DOHC engine you can't turn the cams out of sequence of the valves hit each other. Make sure the key notch on the crankshaft is straight down. Timing notch on the back of the sprocket lines up with the notch on the pump housing. Turn the exhaust cam to the right so it unloads and the valves will be closed, timing notch should point around 1:30. Then turn the intake cam to its timing mark, then turn the exhaust cam to its timing mark. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 26, 2017 Share Posted March 26, 2017 The engine locked up and you put in new rings? Stop right there and explain yourself in more detail. I think that most probably belt timing is your least concern. Subaru's don't lock up because of rings. If they are going to stop turning it's going to be a bottom end (rod bearing) problem not rings. By the time piston rings "locked up" it would have been out of oil for long enough to do MAJOR damage to the bearings. In fact they usually die from throwing a rod. GD Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted March 26, 2017 Share Posted March 26, 2017 Aside from GD's concern, you have the crankshaft in the wrong position for timing. Use the dash mark on the outside of the gear, not the arrow/triangle. Quote Link to comment Share on other sites More sharing options...
Lockett77 Posted March 27, 2017 Author Share Posted March 27, 2017 GD my engine locked up from oil starvation (blown head gasket) so i figured might as well change the rings. And of course i was using the wrong mark on the crank pulley, thanks guys. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 27, 2017 Share Posted March 27, 2017 If it locked up from oil starvation then putting in new rings is not going to fix it. You need a new engine. GD Quote Link to comment Share on other sites More sharing options...
Lockett77 Posted March 28, 2017 Author Share Posted March 28, 2017 Nah this engine is salvageable. Thanks tho Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 28, 2017 Share Posted March 28, 2017 Uh huh. Sure it is I want video of when you start that sucker. It's going to be hilarious. You don't lockup a Subaru engine from oil starvation and get away with it. Aint happening. GD Quote Link to comment Share on other sites More sharing options...
