1997reduxe Posted March 30, 2017 Share Posted March 30, 2017 Hi all. I have a 94/95 2.2 legacy wagon with 150k. I've been getting a constant intermittent abs light for a while. I just wondered other than replacing sensor itself on front wheels, or back for that matter but I'm starting on the front, is the abs ring actually located inside the hub/bearing setup? Just wondering, and it is possible to pull the abs codes? I'm Quote Link to comment Share on other sites More sharing options...
lmdew Posted March 30, 2017 Share Posted March 30, 2017 Usually a bad sensor or stuff on the sensor. The front sensors are behind the disk. Clean the sensors and or read the codes to see the ABS faults. Quote Link to comment Share on other sites More sharing options...
