5 lug parts on a EA82 whats what?
Front hubs/ knuckles will work. Will have to drill out crossmember for the larger bolt on the xt6 control arm. Also swap top hats. Ea82 top hats on xt6 struts.
Inner doj will have to be swapped if not a turbo loyale or turbo trans. Xt6 have 25 spline inner axle cups. NA ea82 has 23 spline.
You can use EJ hubs/knuckles but will have to use ej axles. I think struts can be swapped around like using ej struts on xt6 knuckles or vice versa.
