Trunk problems
4 replies to this topic
#1 Archiefromsv
Archiefromsv
    New User
  • Pip
  • 5 posts
  • Afton
Posted 16 June 2004 - 06:10 PM
:confused: I recently purchased a 1986 XT GL-10 Turbo, and I got it from a person who bought it from the impound. Unfortunately the impound didn't give him a key to start the car so they just put a new ignition in it. One problem is that I can't access the trunk to find out what is it. Are there any hints or tricks to opening trunks on these cars or do I have to go midevil and cut up my backseat?
#2 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,953 posts
  • Denver, Colorado
Posted 16 June 2004 - 06:36 PM
Take the lock out of the passenger door and read the code off it. Then take this code to a Subaru dealer (or two) and see if they can make a key from the code.
If you cant find one that can post the code here and I will try to find you a dealer or shop that can make one. S-Wingstuff in Denver was successful at one point for me too.
Otherwise you can take a screwdriver to the lock and break into it and then replace all the door and trunk locks with a set from a junked car with a working key.
#3 Guest_taprackready_*
  • Guests
Posted 16 June 2004 - 06:55 PM
You can just get a junkyard lock with no key and a locksmith can rework it to use your current key. Just did mine for $10. Much easier than replacing all the locks and the ignition.
Bill
#4 Hocrest
Hocrest
    Function becomes Fun
  • 1,347 posts
  • Cressona/Pittston
Posted 16 June 2004 - 07:24 PM
a. Along the drivers door sill in front of the seat their should be a lever to pop the trunk. Push to pop the fuel door, Pull to pop the trunk...
b. There is a small pull tab at the top of the rear seat that will allow the rear seat back to fold down, allowing access to the trunk...
c. I think the dealer can cut a key if you provide them with the VIN and proof of ownership...
#5 Archiefromsv
Archiefromsv
    New User
  • Pip
  • 5 posts
  • Afton
Posted 17 June 2004 - 07:42 AM
Hey thanks everyone, I'll try it all out and I hope that it works.
