girlysdad Posted April 19, 2017 Share Posted April 19, 2017 My daughter has an "07 Outback. It often takes two or three wiggles of the shift lever in park before the engine will turn over. My dealer has replaced the modulator/interface box on the side of the transmission. I feel that it is a mechanical problem in the linkage itself. Is there a tension adjustment in the cable? Is there a secondary contact closer to the lever in the linkage, other than the modulator/interface? Any information anyone can offer pertaining to fixing this problem would be greatly appreciated! girlysdad Quote Link to comment Share on other sites More sharing options...
matt167 Posted April 20, 2017 Share Posted April 20, 2017 Yes there is. Under by the driveshaft where the shifter connects. Quote Link to comment Share on other sites More sharing options...
girlysdad Posted April 20, 2017 Author Share Posted April 20, 2017 I'm assuming you're talking about the tension adjustment. I'll look for it the next warm day we have here. thanks for the input! Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 23, 2017 Share Posted April 23, 2017 On older ones theres a shift lock device (forget what it's called??) on the shifter that just gets sticky and prevents the car from startung unless it's in Park. On those the inhibitor switch on the side of the transmission isn't the issue. If that mechanism is compromised it can act like it's not in park when it is in park. Jiggling frees it up. I'm unsure how 2005+ are set up. If it's doesn't start and you shift to neutral to start it - what happens? Tell her to quit spilling coke and food down the shifter area. LOL Quote Link to comment Share on other sites More sharing options...
girlysdad Posted April 23, 2017 Author Share Posted April 23, 2017 Thanks, Gary (I'm assuming that's your first name). This helps a lot: It narrows the problem down to only two possibilities. By the way, when I shift into neutral, it starts every time. The car was purchased about a month ago, so I'd like to get hold of those former coke drinkers and junk food eaters. Quote Link to comment Share on other sites More sharing options...
