Fatbuford Posted May 5, 2017 Share Posted May 5, 2017 Guys, On other blog sites I've seen lifted 02-03 OBW. Is there a do's and don't for finding the proper lift kit? I am talking 2" max. Does it affect the driveline geometry like a traditional SUV? Recommendations are welcome. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted May 5, 2017 Share Posted May 5, 2017 On that model 2" or less you can get by with just the strut lift, it will give the axles a greater angle, best to also drop the rear trailing arms Here's my kit for that model, if you go less say 1" just need strut spacers http://www.sjrlift.com/index.php/catalog/lift-kits/0-2-lift-kit-2000-25-detail 1 Quote Link to comment Share on other sites More sharing options...
OSC Jake Posted June 6, 2017 Share Posted June 6, 2017 Thanks, Scott, this is helpful as I'm somewhat interested in a similar build. Do you know if someone could combine that lift with King Springs for more lift, then use sub frame spacers to drop the other components down? My thoughts are that I can get similar geometry compared to just using the 2" spacer lift but allow bigger tires under the car (possibly having to cut fenders as well). Just curious. Thanks again! Quote Link to comment Share on other sites More sharing options...
