ferp420 Posted May 8, 2017 Share Posted May 8, 2017 This is a continuation of this thread http://www.ultimatesubaru.org/forum/topic/163092-and-then-i-saw-this/ but since im building a off road set up i figured i would move the thread here the first stage is new radiose arms im shooting for 2ft long and pushing the wheel forward 1" while adding some adjustabuility to it i picked up some 3/4x3/4 hiem joints and i had some nice heavy pipe the right size and some plate steal to play with First i boogered the sheet metal back on and since its only the tranny mount now it should be fine i am gone reinforce the block though just for the hell of it theres a nice channel for the new rod to sit in theres even a cut in the frame that looks like it was made for it i took some 2x1 tube ans sandwiched the frame rails and cut a plate to weld to it and bolt in to the rear crossmeber bolt holes i also plan to tie it all in to the sliders so it will have plenty of reinforcement it should take alot of the load off the firewall to so the body dosent bend in half lol 1 Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 8, 2017 Author Share Posted May 8, 2017 (edited) Edited October 9, 2017 by ferp420 Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 8, 2017 Author Share Posted May 8, 2017 Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 8, 2017 Author Share Posted May 8, 2017 A Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 9, 2017 Author Share Posted May 9, 2017 Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 10, 2017 Author Share Posted May 10, 2017 Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 10, 2017 Author Share Posted May 10, 2017 I Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 10, 2017 Author Share Posted May 10, 2017 T Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 10, 2017 Author Share Posted May 10, 2017 One side done Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 21, 2017 Share Posted May 21, 2017 You're gonna be bummed when you bend those. Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 21, 2017 Author Share Posted May 21, 2017 (edited) If i bend any part.of this set up ill be stoked im havin so much fun and what the hay i built it.once i can do it again its not like i payed some one to do it for me or spent alot on it the only things i bought were the urithane bushings and the rod ends less than 50 and theres lots of.adjustment left for geting home on bent links lol and its easy to r&r but honestly its got.to be the strongest part.of the entire car but that dosent mean it wont bend when im done the front suspention will tie in to the rest of the sub framelike work that allready conects to the rear k bar sliders tube fenders and front bumper so its gona bend more than just the link when it dose bend but its gona have to be one hell of a hit to bend any part i built in this set up i dont know if im getting my squat ratios right though so ill probably have to redo parts of it anyway but ive got to start somewere i havent seen anyone else do anything like it so i dont have any one to copy its trial and error on this only time and abuse will.tell Edited May 21, 2017 by ferp420 Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted May 22, 2017 Share Posted May 22, 2017 Good work, on the stock setup it's solidly mounted at the lower arm , you have a hiem , I'm thinking that lower arm will want to flex now as its only a pressed u shaped steel arm, I've bent a few of those round radius rods in my days wheelin , will be interesting to see how this works out Quote Link to comment Share on other sites More sharing options...
Uberoo Posted May 28, 2017 Share Posted May 28, 2017 box your lower control arms,and plate the control arm mount. Quote Link to comment Share on other sites More sharing options...
ferp420 Posted May 29, 2017 Author Share Posted May 29, 2017 I Plan on replacing the entire arm with longer ones with hiem joints but if that dosent happen ill box the controle arms in and i like the idea of reinforcing the crossmeber so ill do that too i also plan on building custom struts for the front kinda like pontoontod dude did only on the cheaper side im hoping to find a pair of cheap rebuildable shocks to keep my price down i did find the fox shox for.100 a pop so maybe someday maybe lol i found some super cheap performance shocks that will work for the rear i exspect them to kick but for about 6 months then ill probably need to replace them but they cant be any worse than whats on there now Quote Link to comment Share on other sites More sharing options...
TheGageinator Posted June 17, 2017 Share Posted June 17, 2017 Wow nice work man this is really cool Quote Link to comment Share on other sites More sharing options...
Fubaru Posted July 11, 2017 Share Posted July 11, 2017 Ferp - I can't see the pics but I really hope you meant "tubing" not "pipe". Other than that, cool idea! Quote Link to comment Share on other sites More sharing options...
ferp420 Posted July 15, 2017 Author Share Posted July 15, 2017 (edited) I Dont use the pipe much anymore (bongnow mostly) but photobucket on the other hand is smokin somethin realy good Edited July 15, 2017 by ferp420 Quote Link to comment Share on other sites More sharing options...
