potter2010 Posted May 18, 2017 Share Posted May 18, 2017 Hello,Just a quick newbie question: what is the rod/bar thing circled in the images? I'm trying to track down noise in the front end (another topic) and was poking and proding at things when I noticed that this bar was easily movable and that when I lifted it up and let it drop it hit against the metal below it and made a noise, though different than the noise I'm tracking down. I however cannot figure out what it attaches to or what it's for. I'm thinking it's either not supposed to move or there should be something to stop it from hitting metal on metal. Any help is appreciated! Quote Link to comment Share on other sites More sharing options...
CNY_Dave Posted May 18, 2017 Share Posted May 18, 2017 Car is a ... ? Hard to tell where that is. It looks to be too high to be the front sway bar, but maybe is. Dpes it look like a piece of pipe and has rubber hoses at each end? Quote Link to comment Share on other sites More sharing options...
potter2010 Posted May 19, 2017 Author Share Posted May 19, 2017 Car is a ... ? Hard to tell where that is. It looks to be too high to be the front sway bar, but maybe is. Dpes it look like a piece of pipe and has rubber hoses at each end? Sorry, was typing it out while the wife was talking. It's a 2010 Outback. It almost seems like solid bar than a pipe. It disappeared on each side so I couldn't easily see where it went. It's just above and behind the oil pan, almost directly above the sway bar. I was looking through my repair manual and didn't see it mentioned, or missed it. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 19, 2017 Share Posted May 19, 2017 Power steering pipes, going from one side of the rack to the other. There are 2 of them, one of them has a rubber section in the middle (which can also be seen in the picture), and the one you have circled is metal all the way across. In the box marked "34190C*B" in this diagram: It looks like there is a support bracket pictured there, but the only way Subaru sells it, is with both of those pipes (part number 34190AJ000, MSRP $69.28). 1 Quote Link to comment Share on other sites More sharing options...
potter2010 Posted May 22, 2017 Author Share Posted May 22, 2017 Power steering pipes, going from one side of the rack to the other. There are 2 of them, one of them has a rubber section in the middle (which can also be seen in the picture), and the one you have circled is metal all the way across. In the box marked "34190C*B" in this diagram: It looks like there is a support bracket pictured there, but the only way Subaru sells it, is with both of those pipes (part number 34190AJ000, MSRP $69.28). Hey, thanks! I'm guessing the support bracket has come loose or fallen off then. Since I'm not leaking power steering fluid I think I'll pad the bar and leave it for now or see if I can see a loose bracket. I could not figure out what it was so this is awesome! Quote Link to comment Share on other sites More sharing options...
matt167 Posted May 22, 2017 Share Posted May 22, 2017 go to junkyard and find a tube stand off from a junk car. Does not need to be Subaru, any brand will do. zip tie the line through that hole and use the stand off as a cushion.. Quote Link to comment Share on other sites More sharing options...
