whynot162 Posted May 30, 2017 Share Posted May 30, 2017 I am changing the head gaskets on my car. I am to the valve cover gaskets. The first one went on no issues, the 2nd, drivers side, does not seem to be shaped correctly. The gasket has one corner that is not squared but the cover is, if that makes sense. Thanks It is a 99 with a ej25. So what gives. someone put a different valve cover on it? or is the kit wrong. Quote Link to comment Share on other sites More sharing options...
Mike104 Posted May 30, 2017 Share Posted May 30, 2017 Felpro or Subaru Gaskets? If I recall that engine could have one of two part numbers, It may be that the valve cover was replaced at some point. Quote Link to comment Share on other sites More sharing options...
whynot162 Posted May 30, 2017 Author Share Posted May 30, 2017 it is felpro. The covers from memory were the same the gaskets are not. I put the otherside together last week, now trying to figure out how to get the correct gasket and get this finished. Quote Link to comment Share on other sites More sharing options...
whynot162 Posted May 31, 2017 Author Share Posted May 31, 2017 here is a photo of the issue. I got another set, and it was the same. So I used the one i needed. but thy are they different? is that normal and my car has had one side changed, or is there a problem with the gasket set? I ask, because I have to do this again on another car as it is starting to leak a little. Thanks Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 31, 2017 Share Posted May 31, 2017 96, 97/98, and 99 are all different gaskets on the 25D. To get the right ones you have to get them from the dealer. The gasket is only $9.99 at the dealer. GD Quote Link to comment Share on other sites More sharing options...
whynot162 Posted May 31, 2017 Author Share Posted May 31, 2017 Thanks, strange that they would be so much the same, yet so different. year to year. Quote Link to comment Share on other sites More sharing options...
