d8usti5n Posted June 1, 2017 Share Posted June 1, 2017 So I broke a rear cv axle on my brat over the weekend, Ive got two good rear cv axles from an ea82 wagon, theyre about half an inch longer than the cvs on my ea81 brat.... I know the immediate answer is no dont do it!, but wuth those axles just sitting there, it makes me curious if anyones ever stuck ea82 axles on a ea81? Quote Link to comment Share on other sites More sharing options...
DaveT Posted June 1, 2017 Share Posted June 1, 2017 What part broke? Maybe part of the EA82 ones are the same, and the length is just the long shaft? Quote Link to comment Share on other sites More sharing options...
d8usti5n Posted June 1, 2017 Author Share Posted June 1, 2017 The boot tore, all the ball bearings came out somewhere along the way, and the ball cage slip out onto the shaft. When i took it out the shaft and housing completely seperated. Ive never rebuilt an axel, would this be rebuildable with parts from the ea82 axle? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted June 1, 2017 Share Posted June 1, 2017 you can swap the EA82 inner cup onto the EA81 shaft. Same with the outer as well if your EA82 shafts are double DOJ style. If the EA82 shaft has the fixed outer end CV (87+) the outer end won't swap. Quote Link to comment Share on other sites More sharing options...
d8usti5n Posted June 1, 2017 Author Share Posted June 1, 2017 you can swap the EA82 inner cup onto the EA81 shaft. Same with the outer as well if your EA82 shafts are double DOJ style. If the EA82 shaft has the fixed outer end CV (87+) the outer end won't swap. Awesome info, ill have to give it a go Quote Link to comment Share on other sites More sharing options...
