WreX4 Posted July 4, 2017 Share Posted July 4, 2017 Guys I have 2004 WRX sti rally suspension will it fit my 1998 subaru GC8 ?? Quote Link to comment Share on other sites More sharing options...
wtdash Posted July 5, 2017 Share Posted July 5, 2017 (edited) Hi, The Front struts will bolt-in; the rears will not. You'll need to swap the 'top hats' /strut mounts on the rear struts - or whatever you call it in England. CAVEAT: I'm not clear on what 'rally' means in your British English. Is that a model/trim of WRX, a non-original Subaru suspension, or ??? And if the '04 in UK ALSO USES the 5x100mm bolt pattern like the USA, it should work. In the USA, 2005+ used 5x114.3mm bolt pattern and a different front strut bolt attachment. Td Edited July 5, 2017 by wtdash Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 5, 2017 Share Posted July 5, 2017 you might check-out www.nasioc.com for swap info, but there could still be some differences as mentioned above due to US vs European market models. Quote Link to comment Share on other sites More sharing options...
