Massive hesitation and stalling ... help me get this running!
I have a '94 loyale 5 speed spfi.
Just re-did all of the seals on the engine and have her back in and hooked all up. Starting her up is a little rough but I can get her to stay running. The idle is low and when you step on the gas pedal it will either stall out or sputter and then start to steadily increase rpm but be very hesitant and not keep constant power. also will backfire once and a while when you step on it before the rpm's drop. I checked the TPS and it is within spec and the water temperature sender seems to be doing its job as well.
Sprayed carb cleaner to check for vacuum leaks and didn't find any. Fuel filter is brand new.
I appreciate any help or input that I can get!
