CTS variable or just a switch
Wondering if anyone has monitored an ea82 EDI coolant temp device to see if is a simple rich or not rich switch for ecu or does it give variable ohm reads to ecu to vary fuel delivery?
I want to use it as an egr switch just to operate at op temps
That.makes sense thanks. Fitting ea eighty two t into Brumby without ecu and any wet fuel delivery system. The ecu in donor was not controlling as per manual. It worked all temps all speeds yet all solenoids were good...ecu first found solenoid "stocked to open or shut" so that was fixed. I once had a frequency switch kit for speed control....gave up on idea. Just a temp range digital unit can take care this time. Thanks
