Do these clips/nut have a name how do I get new ones?
5 replies to this topic
#1 mickytrus
mickytrus
    USMB Regular
  • 292 posts
  • northeast
Posted 17 August 2017 - 12:59 PM
Aye,
      We all know these things, these clips or (clip/nuts)  that are receivers of bolts...........  they are mounted all over the place....
You see them  holding the electric fans to the radiator    or  even can be see holding  the  wiper wash bottle to a mounting bracket.....
The ones I am specifically interested in ,   are the ones that hold the electric fans to the radiator.......   1998 subaru outback.....
THEN  a ten mm bolts runs through the plastic frame of the fan to the radiator..... where this  (clip/nut)  allows you to thead into...
the ten mm bolts  THUS,   holding on the radiator  fan to the radiator  securely........
 WHAT ARE THESE CALLED??????   WHERE DO I GET NEW ONES?    should be able to buy a pack of them...
Thanks, MICKY
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,617 posts
  • Portland
Posted 17 August 2017 - 01:32 PM
They are called Speed Nuts. Go to the 80's GM isle at the wrecking yard. They used 6x1.0 speed nuts all over the place.
#3 Mike104
Mike104
    Subaru Fanatic!
  • 667 posts
  • N KY
Posted 17 August 2017 - 02:18 PM
^ What GD said.
If you are feeling all Subaru the OEM part number is 45119AC001 J-Nut.  $2 each from your local dealer.
You can try here:
http://cliphouse.com/MetricUJNuts.aspx
Edited by Mike104, 17 August 2017 - 02:20 PM.
#4 Numbchux
Numbchux
    EJ conversion addict
  • 6,812 posts
  • Saginaw, MN
Posted 17 August 2017 - 02:36 PM
Yep, speed nuts and most auto parts will have an assortment.
#5 Subaru Scott
Subaru Scott
    New User
  • 419 posts
  • Cape Coral, FL
Posted 17 August 2017 - 02:47 PM
eBay. Keep searching through there till you find the best deal. You can probably get 50 for ten bucks with free shipping.
#6 mickytrus
mickytrus
    USMB Regular
  • 292 posts
  • northeast
Posted 18 August 2017 - 10:17 AM
    Thanks!
      The 80's GM isle...... that is great......   Funny, I gotta go there for a tailight.. today
       Thanks! for the other source too.... much appreciated.....
                      Mike104:::  thanks for the link yeah, that works.....jnuts unuts
                      and EBAY......
