Superpro Kit numbers
9 replies to this topic
#1 Vkbikes
Vkbikes
    Advanced Member
  • PipPipPip
  • 33 posts
  • Portland, OR
Posted 24 August 2017 - 10:21 PM
Hello, I've got a set of front control arms off a 89 XT6 for my five lug conversion with busted bushings and I'm trying to figure out if I need the 24mm bushings or 28mm. I tried to measure then but it doesn't really match up.
#2 Skylar
Skylar
    USMB is life!
  • 543 posts
  • Tacoma, Wa
Posted 07 September 2017 - 04:06 PM
Bumping this thread because I'm also in the same boat. Need new control arm bushings for my 5 lug swap.
Some old threads say the ea82s will fit some say they don't. I wonder if early EJ legacy/impreza has the same size bushing
#3 carfreak85
carfreak85
    Temple of Fuji
  • 5,247 posts
  • Cascadia
Posted 08 September 2017 - 09:51 AM
Couple options:
Measure the ID and OD of your current bushings and look on their website for the corresponding dimensions.  Or just call them...
#4 Vkbikes
Vkbikes
    Advanced Member
  • PipPipPip
  • 33 posts
  • Portland, OR
Posted 17 September 2017 - 12:33 AM
Well from what I can tell, there's some mention of super pro SPF1144K, but there's no mention of sizing, just that they fit a Leon chassis wagon rear trailing arm.
#5 Vkbikes
Vkbikes
    Advanced Member
  • PipPipPip
  • 33 posts
  • Portland, OR
Posted 20 September 2017 - 08:51 PM
I contacted Superpro and the SPF1144K kit is very close to the XT6 sizes.
For your viewing pleasure, here is a comparison on engineering paper.
https://i.imgur.com/p0OOSGk.jpg
#6 Vkbikes
Vkbikes
    Advanced Member
  • PipPipPip
  • 33 posts
  • Portland, OR
Posted 21 September 2017 - 08:59 PM
For the sway bar bushings on the xt6 arms, SPF1815 with SPF3110T tubes should work.
There will be a 2mm gap in the center but that shouldn't matter.
https://i.imgur.com/m0pKmVP.jpg
Edited by Vkbikes, 21 September 2017 - 09:02 PM.
#7 Skylar
Skylar
    USMB is life!
  • 543 posts
  • Tacoma, Wa
Posted 23 September 2017 - 10:11 AM
Vkbikes did you end up ordering the spf1144k kit for your control arms? It's listed as the trailing arm kit.
Edited by Skylar, 23 September 2017 - 10:14 AM.
#8 Vkbikes
Vkbikes
    Advanced Member
  • PipPipPip
  • 33 posts
  • Portland, OR
Posted 23 September 2017 - 10:24 AM
I haven't yet, but that's what I intend to order.
It would appear the Loyale/gl trailing arm is the same bushing as the xt6 front.
The overall width of the sp1144k kit when installed will be 2mm wider then stock. I have not yet confirmed that this will fit, but it should.
Edited by Vkbikes, 23 September 2017 - 10:27 AM.
#9 Skylar
Skylar
    USMB is life!
  • 543 posts
  • Tacoma, Wa
Posted 23 September 2017 - 12:14 PM
Right on. I suppose I'll give it a shot too. 2mm is about 1/16th of an inch so I don't see a problem with it fitting either. Worst case scenario you'll probably have to open up the slot for the control arm on the crossmember.
#10 Vkbikes
Vkbikes
    Advanced Member
  • PipPipPip
  • 33 posts
  • Portland, OR
Posted 23 September 2017 - 12:27 PM
Right. And you might be able to trim the center of the bushing as well. Now if only they didn't cost $80
