Subarule Posted August 31, 2017 Share Posted August 31, 2017 A flywheel on an '86 GL 5-spd. With 4WD, if that matters. I'm wondering if the price I was quoted from a highly-regarded trans shop is typical. The quote includes draining & replacing the trans oil. Does anyone have experience with a shop doing this work and a fair price range? I don't want to give the quoted price here, just wanting to get some prices in order to compare. I am in SW Washington state. Quote Link to comment Share on other sites More sharing options...
jsyme Posted August 31, 2017 Share Posted August 31, 2017 (edited) Deep gouges in the flywheel will just kill the new clutch. It has to be milled or replaced. Make sure the replacement isn't cheaper than the milling fee. Edited August 31, 2017 by jsyme Quote Link to comment Share on other sites More sharing options...
Gloyale Posted August 31, 2017 Share Posted August 31, 2017 Tpically this type of job is done when replacing a clutch. No ussual to pull the trans to just resurface a flywheel. I ussually charge about $300 in labor for R+R of trans. Plus $50 for flywheels surface. $20 fluids and rags. Plus the cost of the clutch set, ussually $100~$175 depending on type and source. So if you are getting this done for around $500 total, that's what I would expect.....more than that is getting into gougin territory. Quote Link to comment Share on other sites More sharing options...
Subarule Posted August 31, 2017 Author Share Posted August 31, 2017 I'm not understanding this part: "No ussual to pull the trans to just resurface a flywheel." Do you mean it is usual, or is not usual? Quote Link to comment Share on other sites More sharing options...
Subarule Posted August 31, 2017 Author Share Posted August 31, 2017 Getting a new clutch was not factored into the price I was quoted. If the flywheel is resurfaced would I need a new clutch? Not that I think hanging onto the old one would be beneficial. I would love a new clutch. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 31, 2017 Share Posted August 31, 2017 (edited) If I was paying Labor or heck even since I do it myself I'd be installing a new clutch. That's a big job - new clutch, throw out bearing and pilot bearing every time as well as the resurface. Edited August 31, 2017 by idosubaru Quote Link to comment Share on other sites More sharing options...
Gloyale Posted September 1, 2017 Share Posted September 1, 2017 I'm not understanding this part: "No ussual to pull the trans to just resurface a flywheel." Do you mean it is usual, or is not usual? It is not usual. Who is telling you to resurface your flywheel? What problem are you having? There really is not ever a reason to resurface a flywheel unless it is related to a failed clutch. Quote Link to comment Share on other sites More sharing options...
