05 forester, no start after engine rebuild, can't hear fuel pump
Check engine light on? Have you scanned it for codes?
Double check connectors.
Two big connectors on the passenger rear of the engine where the harnesses join.
Plug on the ignition coil.
ECU Grounds on top of the intake manifold.
Crankshaft and camshaft position sensors.
Last would be to check the timing belt. Make sure the marks are all correct and hasn't jumped. Did you remove the cam sprockets? If so, Did you make sure to install them back on the correct side? Left sprocket has notches on the back for the cam position sensor to read. If you switch sprockets the sensor doesn't give a signal and you'll get a no-spark condition.
Edited by Fairtax4me
  • Like 1
