86 brat with weber questions
5 replies to this topic
#1 nicksubaru
nicksubaru
    Advanced Member
  • PipPipPip
  • 117 posts
  • mariposa California
Posted 18 September 2017 - 05:25 PM
The carb is the weber 32/36 dgav 33b1, im not the one who did the weber swap. In the front of the carb there is something missing, after some searching i think its the primary idle jet and holder for it. I was able to plug it with a small alin bolt with the same thread. Now it will idle but what will happen if i dont replace the jet that's supposed to be in there? Is there a shop that i can go to in person that carries parts for this? (in California) The local o'reilly's does not have anything for it. I tried to order a new jet and holder online but its not right...
#2 naru
naru
    1000+ Super USER!
  • 2,259 posts
  • under the bridge
Posted 18 September 2017 - 08:01 PM
IIRC,the jets? and holders come in 2 sizes for the DGV series carbs.
Order the other one(s).
http://www.dellortos...V_and_DGEV.html
Edited by naru, 18 September 2017 - 08:39 PM.
#3 nicksubaru
nicksubaru
    Advanced Member
  • PipPipPip
  • 117 posts
Posted 19 September 2017 - 02:57 AM
IIRC??? I don't know what that means.
So just the holders are 2 different versions ? They use the same jet? Or is there two different versions of the jets as well? I think i ordered the Smaller one so i need the bigger ones
#4 naru
naru
    1000+ Super USER!
  • 2,259 posts
  • under the bridge
Posted 19 September 2017 - 06:22 PM
IIRC = if I recall correctly
Website above shows 2 different sizes for both idle jets and idle jetholders.
#5 Nickoli
Nickoli
    Advanced Member
  • PipPipPip
  • 37 posts
  • Paonia, Colorado
Posted 19 September 2017 - 09:43 PM
If it's one of two openings on the front (facing the bumper of the car) they are both vacuum ports. I forget exactly, but the left one is connected and the right one can be plugged.
try looking through loyale 2.7's weber swap guide and i bet it's there somewhere.
the primary idle jet is on the driver's side of the carb, if i remember correctly. i can also check tomorrow. can you take a picture of what's missing?
#6 nicksubaru
nicksubaru
    Advanced Member
  • PipPipPip
  • 117 posts
Posted 20 September 2017 - 12:31 AM
If i need a better pic of it let me know
