* * * * - 1 votes
My 97 Legacy won't change air positions
air legacy mode actuator blender door defroster
5 replies to this topic
#1 Dude_aru
Dude_aru
    Newbie
  • Pip
  • 2 posts
  • Sacramento, CA
Posted 20 September 2017 - 05:06 PM
Pretty self-explanatory title, I can't move the air flow from the mid/head level. I press the buttons and the lights change, but I don't hear anything inside and it stays where it is. Anything I can do easily to change this? I wanna be able to use my defrosters this winter.
I have done some research and heard some possible issues could be a vacuum leak, blown fuse or an issue with the blender door or mode actuator.
#2 gbhrps
gbhrps
    20 Year Subie Fan
  • 1,103 posts
  • Canada
Posted 20 September 2017 - 06:35 PM
Dude_aru,
Check the fuses for the HVAC system (I suspect its not that, but first things first), and then zero in on the dash control unit.
Pull the center dash surround and remove the screws that hold the HVAC  control unit to the dash. Pull the unit clear of the dash and check the control unit as per the factory service manual page PDF file I've attached. If anything is out of spec, either take the control unit apart and clean its contacts for every switch with electrical contact cleaner spray, and see if you can't get it working again.
Either that or get a used one from a wrecking yard. Good Luck!
    Attached File  MSA5TCD97L3731.pdf   64.22K   5 downloads
#3 Dude_aru
Dude_aru
    Newbie
  • Pip
  • 2 posts
  • Sacramento, CA
Posted 20 September 2017 - 06:55 PM
Dude_aru,
MSA5TCD97L3731.pdf
Do you know what fuse it would be I can't seem to find it
#4 Stevo F
Stevo F
    USMB is life!
  • 218 posts
  • Virginia
Posted 21 September 2017 - 09:15 PM
My '98 Legacy acted the same way after we bought it 4 years ago. it ended up to be an issue with the climate control unit itself. I found another on Ebay and it's worked well ever since.
#5 Rooster2
Rooster2
    Subaru Master
  • 4,706 posts
  • Indianapolis
Posted 23 September 2017 - 07:58 AM
Had the same problem with my 98 Outback. Just too much soft drink spills that worked its way into the climate control buttons. Usually, I could clean out the crud with windex, but after a while that did not work very well. I would push a button, and nothing would change. Replaced with unit from wrecking yard, and all is well, except that some of the button indicator lights don't work.
#6 Mike104
Mike104
    Subaru Fanatic!
  • 690 posts
  • N KY
Posted 23 September 2017 - 11:35 AM
http://www.ebay.com/...5.c100005.m1851
Or check your local pull and pay yard.
Also check www.car-part.com and search near you
Edited by Mike104, 23 September 2017 - 11:37 AM.
