97 legacy outback
3 replies to this topic
#1 letitburn1
letitburn1
    Newbie
  • Pip
  • 3 posts
  • Henrietta Tx
Posted 25 September 2017 - 03:04 PM
Yes I had a topic before and I believe no one responded.  But I can believe that because it was very broad.  I've since done a compression test on my motor.  It will not start and idle.  The compression test came back good.  It has a stinger computer in it.  The oil pressure gauge recently went back and was leaking oil inside the wire box.  I believe its a short that is causing it to not start.  What should I do?
#2 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,714 posts
  • Texas
Posted 25 September 2017 - 10:18 PM
you may be able to use electronics cleaner to clear-out the oil. It is unlikely to be causing a problem but, I'd try to clean it. Or, try brake cleaner or WD-40, maybe followed by electronics cleaner?
was there a wreck or work done before the the car became inoperable? Sometimes when the engine is worked on, the IACV's hose gets dislodged from under the intake tubing.
#3 1 Lucky Texan
1 Lucky Texan
  • 7,714 posts
  • Texas
Posted 20 October 2017 - 09:01 AM
still have starting problems?
#4 deano77
deano77
    Newbie
  • Pip
  • 3 posts
  • asheville nc
Posted 24 October 2017 - 10:32 PM
check for vaccum leak
