crawdad Posted October 1, 2017 Share Posted October 1, 2017 Has anyone out there with a 1985 brat ever had a problem with their Brat pull to the left under acceleration and instantly pull to the right when you let off the throttle? This has been happening for the last year or so and its not just a slight pull it's a major movement. Quote Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted October 1, 2017 Share Posted October 1, 2017 Dragging a brake pad on front right ? Semi seized caliper. Only other idea I have is front diff or cv trouble.. ie... only supplying drive to front left wheel. Cheers. Quote Link to comment Share on other sites More sharing options...
charles_thomas Posted October 1, 2017 Share Posted October 1, 2017 (edited) Could be alignment. Acceleration can shift the front up and then down enough to allow bump steer.Pretty common on a vehicle with less than new suspension, especially if the toe in was set with the wheel crooked, or hasn't been set in a while. Fairly easy to check too. As always, start with the simple stuff and work from there. Edited October 1, 2017 by charles_thomas Quote Link to comment Share on other sites More sharing options...
Gloyale Posted October 1, 2017 Share Posted October 1, 2017 radius rod bushings wheels toe in during acceleration and toe out under decel Quote Link to comment Share on other sites More sharing options...
crawdad Posted October 1, 2017 Author Share Posted October 1, 2017 Thanks everyone for the information I will start with alignment and check bushings then go from there, it has new struts and ball joints and new axles, haven't thought about the brakes and they are new too, could be stuck caliper but it seems to free wheel when I jack it up, also I have noticed the left (drivers side) front wheel lines up with the edge of the fender and the right (passenger side) is inside the fender, not sure if it's supposed to look like that. Quote Link to comment Share on other sites More sharing options...
MR_Loyale Posted October 2, 2017 Share Posted October 2, 2017 The only time I experienced torque steer was with a new axle on one side. It was stiffer than the other side. Eventually it worked itself out as the new axle was worn in. Quote Link to comment Share on other sites More sharing options...
