Put new tires on the 97 Legacy at the beginning of summer.the rears are already more than half worn out on the inside with cupping and scaloped edges.the fronts still look real nice.the car is AWD 5 speed.what could be causing this?tire brand is General Altimax.need to figure this out!tires are exspensive!
Edited by Torry33
Were the tires that you replaced at the beginning of summer wearing out in the same manner as what you are seeing on the rear tires right now? If so, the tire shop should have given you notice of this, and as others have said, advised you getting an alignment or strut replacement, before installing new tires. That is what my tire shop has done.
thanks for all the input guys!i just got a parts car with 147k.the body is shot but wil be using it for lots of parts.I found that one of the rear arms is bent and the other side has a bad wheel bearing.and yes General tires wear out fast!
Edited by Torry33
  • Like 1
