2007 legacy transmission in 2004
9 replies to this topic
#1 jread
jread
    Eat, Live, Breath Subaru
  • 287 posts
  • Vancouver, BC, Canada
Posted 14 October 2017 - 10:51 AM
Want to buy a legacy next week but it has an issue with the speedo.
The Po put in a 2007 transmission to replace a 2004 with a shot bearing and now the speedo doesn't work. It's my understanding that the 2007 uses a speed sensor in the abs where the 2004 uses one in transmission.
How do I get the speedo to work? Can I install the VSS from the 04 trans on 07 or can I throw and abs speed sensor and hook it to my 04 ecu?
#2 86BRATMAN
86BRATMAN
    Elite Master of the Subaru
  • 3,944 posts
  • Tazewell Virginia
Posted 14 October 2017 - 11:01 AM
Look at the Dakota Digital sgi-5 or the vsspro. They are devices that tap into abs speed sensors and convert it to a signal that the speedometer and ecu can read.
#3 GeneralDisorder
GeneralDisorder
  • 21,690 posts
  • Portland
Posted 14 October 2017 - 11:22 AM
VssPro is the ticket. It's $199 and can make the 2004 speedo work with the later trans. I've used them before for late model 6 speed swaps.
Edited by GeneralDisorder, 14 October 2017 - 11:23 AM.
#4 jread
jread
  • 287 posts
Posted 16 October 2017 - 06:44 PM
No way to do it with parts from the old trans?
$200 USD is steep for a speedo!
Although that Dakota unit is way cheaper!
#5 GeneralDisorder
GeneralDisorder
  • 21,690 posts
  • Portland
Posted 16 October 2017 - 11:16 PM
Correct there is no way to do it with parts from the old trans - unless you want to swap the entire front differential and housing..... I have the Dakota unit in my Trans Am and while it works, it's highly susceptible to EMI and the Speedo likes to jump around like crazy when I'm stopped. Probably could fix it with some shielded com wire but yeah.... It's a cheap unit. The VssPro is much better.
Edited by GeneralDisorder, 16 October 2017 - 11:17 PM.
#6 jread
jread
  • 287 posts
Posted 18 October 2017 - 02:24 PM
Weird. I think I'll probably just get some shielded wire then! Thats $120 big ones for a seemingly small bit of hassle.
My only question now is where am I getting speed signal from since the trans doesn't have it and neither do the ABS sensors?
#7 GeneralDisorder
GeneralDisorder
  • 21,690 posts
  • Portland
Posted 18 October 2017 - 09:57 PM
The VssPro uses the ABS wheel speed sensor.  Specifically the front right sensor.... I'm sure the Dakota unit could do this also but it's not setup especially for that. You will have to determine the conversion factors and program it yourself.
#8 86BRATMAN
86BRATMAN
  • 3,944 posts
  • Tazewell Virginia
Posted 19 October 2017 - 04:04 PM
http://www.rs25.com/...#/topics/212411
#9 jread
jread
  • 287 posts
Posted 22 October 2017 - 12:33 AM
Ohhh I didn't realize that the 2004 already had the sensor.
Bratman your link doesn't work
#10 86BRATMAN
86BRATMAN
  • 3,944 posts
  • Tazewell Virginia
Posted 22 October 2017 - 12:26 PM
Google search Dakota digital subaru and it'll turn up the link. I forget this forum breaks links sometimes.
