EA81: Distributor?
I have an 85 Brat that isn't getting spark. New plugs, new plug wires, new ignition coil, new disty cap and rotor. I pulled out the distributor and noticed the distributor shaft has about 1/8 inch vertical play and 1/16 horizontal play. Is that too much on both sides? Do I need to replace the whole distributor? Could that be why it doesn't start? Any info is appreciated.
Alright i'll check tomorrow. I showed my shop teacher the movement in the disty and it does move enough side to side that blades of the piece that rotates hits the pieces of metal on the top. He said it might be enough to make it spark incorrectly and not start. No contradicting what you all said, just saying what he thinks.
Ok I will check for power at the coil tomorrow and found a refurbished distributor. Is this the right distributor for an EA81 Hitachi carb/distributor Brat? I ordered a cap and rotor from them before and it didn't fit, so I don't want that happening again.
https://www.partsgeek.com/gbproducts/MC/322-07003437.html?utm_content=MC&utm_term=1981-1987+Subaru+Brat+Ignition+Distributor+A1+Cardone+31-810+81-87+Subaru+Ignition+Distributor+1983+1984&fp=pp&gbm=a&utm_source=google&utm_medium=ff&utm_campaign=PartsGeek+Google+Base&gclid=Cj0KCQjw1JbPBRCrARIsAOKj2PlvvW9CSahNkLg2xXQaYVXN60mdBpujE9aQP1vnTaB1NL4LYb2Sy2IaAkxCEALw_wcB&ad=47584901292
The Hitachi is the one you want.
For some reason,  :blink: the EA81s came with two different distributors. Hitachi on the 4WD and Nippondenso on the 2WD. Don't ask me why, I think it was political.
The Hitachi's had a problem with bushing wear, mostly attributed to the oil grooves in the shafts gumming up from neglected oil. I used to rebuild these myself, and had a machine shop making the bushings. The Hitachi electronics are extremely robust, and I have yet to see one fail.
The Nippondenso's had no bushing problem, but the electronics would wink-out with no warning and leave you walking.
Yes, the one in your link is right.
And just to elaborate on the differences, The Hitachi only had a vacuum advance. The ND had a vacuum advance/retard.
Either manufacturer could have provided both.
That was the only practical difference between the two, and either will work with just a difference in advance curve.
