StephenA Posted October 19, 2017 Share Posted October 19, 2017 So I just finished putting the engine back into the car after doing the head gaskets. Took it for a drive down my mountain. Now the brake is locked up tight. Could this be part of the hill holder? I might have missed a connection when putting the engine back in? Looking in the Chilton manual shows a hill holder, but not what to look for or how to adjust. Ideas please! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 19, 2017 Share Posted October 19, 2017 Could be. The hill holder mechanism is on the frame rail just below the master cylinder. Cable runs from the lever on the hill holder to the clutch release fork. Cable adjusted too tight can cause the brake to drag. The cable needs adjustment if the clutch release cable is adjusted. If your clutch release point is fine, then just loosen the hill holder cable until there is slack in the cable. Then tighten until the cable just starts to pull against the lever. Quote Link to comment Share on other sites More sharing options...
StephenA Posted October 19, 2017 Author Share Posted October 19, 2017 Thank you. That makes a lot of sense. I'll check it out tomorrow. Quote Link to comment Share on other sites More sharing options...
