Lunagurl2000 Posted October 24, 2017 Share Posted October 24, 2017 I have replaced doors on a couple of cars in the past (All other car Types). It's my first time working with a Subaru. A friend of mine wants me to replace the rear right side door. This question may sound stupid... but, can you use different year doors from this model to replace it? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 24, 2017 Share Posted October 24, 2017 (edited) Yep. As long as it’s the same generation (style door), there’s usually 4 or 5 years of models that all work. It’s like - couple bolts and the hinge pin and electrical connector. Very easy. I think 2010 was a new model year so somewhere around 2010-2014 should work - but verify the exact starting and ending years first, I’m just guessing. Verify generation (what years work) and color match. Ideally you use the color code as sometimes Subaru has changed colors mid-generation or there’s a White and Pearl White. But that rarely happens. Legacy and Outback may or may not interchange. I’ve done it before on older models and it works but sometimes the cladding or pin striping is slightly different. And I don’t know if newest gen leg and outback are still interchangeable for certain. The junk yard database should tell you. Then you swap away. You can transfer interior panels to match. Install old interior panel on new door so you don’t have to worry about matching interiors. Edited October 24, 2017 by idosubaru Quote Link to comment Share on other sites More sharing options...
heartless Posted October 25, 2017 Share Posted October 25, 2017 www.car-part.com is your friend in cases like this... input the year & model of what you have & the part you are looking for, and it will return compatible items. Quote Link to comment Share on other sites More sharing options...
