syphon Posted June 22, 2004 Share Posted June 22, 2004 Hey all, I have a '93 Turbo Legacy. EJ22t, 5-spd AWD. I'm starting to notice slight problems with my power steering system. When the car gets all warmed up (say after my long commute to work), the power steering pump gets very whiney from about 900rpm to about 2,000rpm. My other car is a Ford, so I'm used to whiney sounding power steering pumps. Lately, the problem has gotten a bit worse. Whenever I'm in a parking lot, my car has a noisy PS pump, and when I turn I can feel the steering wheel vibrate a little (I can almost feel the PS pump laboring away). And even worse, occasionally the wheel shudders when I turn at very slow speeds, or almost stopped. I checked the fluid, and it looks fine. The belt also appears fine. What do you guys think the problem could be? Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted June 22, 2004 Share Posted June 22, 2004 take the belt off. try to turn the shaft. it should turn freely, yet not have any slop in it. If it doesn't turn smoothly/freely or has some play in the shaft, you're goin to need another pump. Quote Link to comment Share on other sites More sharing options...
brus brother Posted June 22, 2004 Share Posted June 22, 2004 Last time I had symptoms, I too thought the fluid "looked fine" but in reality, the fluid level was low! I'm not sure how the reservoir is set up but it took a fair amount of Dextron to top it off. Symptoms gone. Quote Link to comment Share on other sites More sharing options...
syphon Posted June 22, 2004 Author Share Posted June 22, 2004 Last time I had symptoms, I too thought the fluid "looked fine" but in reality, the fluid level was low! I'm not sure how the reservoir is set up but it took a fair amount of Dextron to top it off. Symptoms gone. The fluid level is way up there, in fact it might be a hair too full, but not sure. I'll try checking the pulley to see if it spins without any "slop". Quote Link to comment Share on other sites More sharing options...
lmdew Posted June 23, 2004 Share Posted June 23, 2004 I have a good used rack and pump if you need them. Lmdew@hotmail.com Quote Link to comment Share on other sites More sharing options...
brus brother Posted June 23, 2004 Share Posted June 23, 2004 Is there such a thing as overfilling the PS reservoir? Quote Link to comment Share on other sites More sharing options...
