sparkyboy Posted November 19, 2017 Share Posted November 19, 2017 (edited) Hey there fellas, 2002 legacy sw Parking or running lamps don't come on at all. Every other light works. No matter what position the light switch is in, or the position of the switch on the top of the steering column. I know that switch on the column is supposed to turn on the parking lamps no matter if the key is in, so i am thinking that is the problem and the entire combo switch needs to be changed? I have a spare combo switch and will just swap the plugs to see if this fixes the problem tomorrow, but i am just wondering if anyone has experienced this particular issue. Pain in the rump roast to swap as the steering wheel has to come off, but whatever. Cheers boys Edited November 19, 2017 by sparkyboy 1 Quote Link to comment Share on other sites More sharing options...
golucky66 Posted November 19, 2017 Share Posted November 19, 2017 Parking lights are on a separate fuse I believe. Start there. Quote Link to comment Share on other sites More sharing options...
sparkyboy Posted November 19, 2017 Author Share Posted November 19, 2017 Update, looked it over, fuse #5 caused the issue if anyone else experiences this Quote Link to comment Share on other sites More sharing options...
sparkyboy Posted November 19, 2017 Author Share Posted November 19, 2017 Thanks golucky you called it. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 20, 2017 Share Posted November 20, 2017 What caused the fuse to burn? Fuses don't typically burn out on their own. 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 20, 2017 Share Posted November 20, 2017 What caused the fuse to burn? Fuses don't typically burn out on their own. I'm gonna suggest this may point to bad wiring in the body-to-hatch boot. I suppose some corrosion in the sockets or a pinched wire, etc. are all possibilities. Quote Link to comment Share on other sites More sharing options...
