Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
checking continuity correctly?
#1
Posted 21 November 2017 - 09:07 PM
I used to use the diode test point on my mm rotary dial but suspect not correct
I am learning how to test my 87.5 dizzy with black round plug and is disconnected with ignition on pro king body side of plug....probing....
#2
Posted 21 November 2017 - 09:47 PM
You can use the diode check as a quick, down and dirty method, but it will not tell you the resistance of the circuit. Checking continuity also means checking resistance. Anything over 5-10 ohms means something is going on somewhere. Resistance=voltage drop or signal interference which can result in it acting like an open circuit depending on the resistance. Use the ohms setting.
#3
Posted 21 November 2017 - 10:42 PM
Also, with some cases of dirty connections, or loose contacts, ohms can falsely indicate that a wire is ok. To be 100% sure, you have to use other information, and draw current appropriate to the circuit that the wire is in would normally see. I've seen situations where ohms would indicate the wire is ok, but try to pull a few amps through it, and it's open, or high enough resistance to interfere with the load operating.
#4
Posted 22 November 2017 - 10:34 AM
+1 You can have continuity and still not be able to draw enough amperage. If you have ten strands in your wire and all but one are broken somewhere or a terminal is only making partial contact, you won't be able to draw the require amperage.
