Throwing misfire #2 on 99 outback . have done everything.
19 replies to this topic
#1 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
  • Lake Tahoe Babieeeeee
Posted 25 November 2017 - 09:47 PM
throwing 302 code on my 99 ob.
so changed plug, coil and wires.
still running rough and throwing this misfire code.
anything else i can do? going to do compression check tomorrow.
Edited by roadsubiedog, 26 November 2017 - 08:51 AM.
#2 06SubLegTx
06SubLegTx
    USMB is life!
  • 157 posts
  • Fort Worth, TX
Posted 25 November 2017 - 10:03 PM
throwing 402 code on my 99 ob.
Hello, How many miles on the car?  Have you inspected the Engine Ground Straps under the car? One on each side of the engine?  How are the battery cable / post? very Clean?
Have you ever had the injectors properly / professionally cleaned?  My 06 Legacy with 99k on it have 2 injectors that were not properly working.
#3 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 25 November 2017 - 10:20 PM
283k miles. have not checked the engine ground straps. will do. battery posts very clean. injectors have not been pro cleaned.
this used to be a hwy car on a 85 mile commute daily until I retired. last 2 years just run around town 5 miles at a time. does this point to something.?
it bogs down a little from a start and then when the rpms are up , it runs fine for a bit like the number 2 is firing ok. then bogs at lower rpms.
can try some injector cleaner in gas and check those ground straps. have owned the car since 05 and never checked those. the motor was taken out for headgaskets about 100k miles ago.
#4 06SubLegTx
06SubLegTx
    USMB is life!
  • 157 posts
  • Fort Worth, TX
Posted 25 November 2017 - 10:39 PM
My 06 Legacy with 99k, was a northern car. My driver ground strap was held on by 1 stand...  Maybe EGR Valve is clogged shut or open.  Mine was very dirty at 99k, yours might be not working at all. The Subaru one are not expensive
#5 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,936 posts
  • Portland
Posted 25 November 2017 - 11:45 PM
When the head gaskets were done, was the valve lash adjusted?
Do a compression check. At that mileage you are probably looking at a burned exhaust valve.
#6 idosubaru
idosubaru
  • 24,022 posts
  • East Coast
Posted 26 November 2017 - 12:18 AM
throwing 402 code .
You say "misfire" in the title - but that code is an EGR code.
Was that a typo and you meant to type "302", or it's a "402" or you have a perceived misfire and "402" or actual misfire - "302" and "402"?
1. swap fuel injectors and see if the misfire stays with cylinder #2 or moves with the fuel injector
2. check valve clearance
3. leak down or compression test like GD said
4. probably not the issue - but make sure the #2 cylinder doesn't have oil in it from the spark plug tube seals leaking
I see what you did there! har har har!!
Edited by idosubaru, 26 November 2017 - 12:18 AM.
#7 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 26 November 2017 - 08:57 AM
ya. 302 not 402.
more info. no oil on spark plug boot.
will do compression test. not sure how to swap injectors. i'm just a everyman. not a subie mechanic.
oh, the plug i took out looked very good, almost perfect condition. they were changed when the T-belt was done less than 30k ago.
would this point the problem elsewhere?
Edited by roadsubiedog, 26 November 2017 - 08:58 AM.
#8 GeneralDisorder
GeneralDisorder
  • 21,936 posts
  • Portland
Posted 26 November 2017 - 11:06 AM
It's probably not an injector. Do the compression test first. #2 and #4 are the cylinders that always burn exhaust valves. Chances are it needs a set of exhaust valves and some news rings at that mileage.
#9 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 28 November 2017 - 05:32 PM
update 11=29-17
I unplugged the injector and no change. so i started to plug it back in and it revved up to normal for a second and then went back to the rough idle. so i tried that several more times and the same thing happened.
would idle fine for a second or so and then back to rough. does this point to a bad injector or a bad connection? all the ends are very clean and when i tried wiggling it with it on the rpm's did not change.
the cel went on again for 264 . low injector . that's probably because i unplugged it.
so , is a new injector next? I have replaced everything else so far, plug, wire , coil.
or can i take injector out and clean it? or just better to replace. oh. I guess i can switch #2 an #4  as someone suggested.
#10 GeneralDisorder
GeneralDisorder
  • 21,936 posts
  • Portland
Posted 28 November 2017 - 07:01 PM
Did you perform a compression test?
#11 idosubaru
idosubaru
  • 24,022 posts
  • East Coast
Posted 28 November 2017 - 07:11 PM
Do not replace the injector, your results are not a diagnosis, or telling. Injectors rarely fail. It’s just free and easy to test by swapping them so I suggested it.
check the compression like GD said.
#12 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 28 November 2017 - 07:24 PM
ok. will report back.
#13 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 01 December 2017 - 01:54 PM
is there an easier way to release fuel pressure before switching injectors? other than unplugging fuel relay way under the dash on drivers side?
this is for a 99 outback.
haven't been able to identify where the fuse is for this if i could just do this.
#14 golucky66
golucky66
    Subaru Nut
  • 585 posts
  • Barkhamsted Connecticut
Posted 01 December 2017 - 02:26 PM
Yeah. Disconnect the feed line at the engine and let it spray on the engine a little.
#15 idosubaru
idosubaru
  • 24,022 posts
  • East Coast
Posted 01 December 2017 - 02:48 PM
this - i've done it like 100 times, no big deal. a  little squirts out and then done.  you can try to wrap with shop towels/etc to contain most of it.
#16 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 01 December 2017 - 03:26 PM
#17 john in KY
john in KY
    1000+ Super USER!
  • 1,672 posts
  • KY
Posted 01 December 2017 - 05:13 PM
The fuse for my 08 is inside the underhood fuse panel. The fuses are identified also.
#18 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 13 December 2017 - 04:19 PM
ok switched the number 2 and 4 injectors and nothing has changed . the engine still runs crappy as before. however i did everything possible to get the cel to come on and it won't. tried going up hills and flooring it and went about 5 miles and no cel.
not sure what to do now. was hoping for misfire on number 4.
#19 rocketman
rocketman
    Advanced Member
  • PipPipPip
  • 111 posts
  • fort covington new york
Posted 13 December 2017 - 04:47 PM
How was compression test?
#20 roadsubiedog
roadsubiedog
    USMB is life!
  • 340 posts
Posted 13 December 2017 - 06:05 PM
update; 12-13-17
it's working fine now by mistake. i pulled the plug out of the #4 injector ( that has the number 2 there now ) to see if there was any change and there was no change.
then when I was putting plug back on the rpm's went back to normal just like before when i tried this before the switch. when i pushed the plug all the way on it ran crappy again. so i removed plug again and when i did i moved the injector plug end from 6 o'clock to about 8 o'clock. this was by accident when i was trying to get the plug off again.
when i put the plug back on, i did not push it on all the way and now it runs fine. i took it for a test drive and it runs fine.
my guess is , is that it is the male parts on the injector  end. not sure how i can fix this but the angle of the injector end must be giving it a proper connection when it is plugged in.
