mykal Posted November 30, 2017 Share Posted November 30, 2017 Swamping out the crank pulley and the boss / spacer came out and didn't get aligned correctly on the reinstall. Need help on the parts list. We're ordering a new bolt, o-ring, and boss but we're not sure what else we will need up to the sprocket. In the pictures you can see the back of the boss damaged at the keyed opening. At the sprocket it looks like the key is the piece at about 10 o'clock and it's also damaged. I think the sprocket is good, is that little piece the key #E50506? and is the shiny metal ring behind it against the sprocket a separate piece or part of the sprocket? Anyone who has any additional information please help, thank you. 1 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 1, 2017 Share Posted December 1, 2017 In general a Subaru only needs the crank pulley bolted on, that’s it. You don’t need Anything else. The key isn’t necessary at all unless you’re planning on installing the bolt too loose. 3 foot pipe over socket, crank down the bolt and the crank pulley will not come off. I’ve repaired tons of these - mangled cranks, keys, pulleys from pulleys that weren’t installed right enough. Just clean up the metal shavings, make sure the sprocket isn’t damaged such that it’ll damage the timing belt, massage until pulley sits flush and bolt it on. If you have an older gen with distributor, where you want to be able to set the timing off the crank then just stick any small bolt/wooden dowel, coat hangar, etc - through the dowel pin holes to line up the crank pulley. Sure if you want the key and H6 cover and get it all perfect then have at it but they are not necessary. Maybe my phone isn’t showing the whole thread but I don’t see any pictures or info. Don’t know what vehicle you’re working on or trying to do it what happened? I have no idea what you mean by “boss” and other words you’re using. Crank pulleys don’t have orings although EZ H6s have a cover that maybe had an oring. It’s not necessary or requires. It yeah replace it if you want. Quote Link to comment Share on other sites More sharing options...
mykal Posted December 1, 2017 Author Share Posted December 1, 2017 2017 BRZ Trying pics again. After looking at them on the computer vs phone I can see a crack in the sprocket now too. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 1, 2017 Share Posted December 1, 2017 ah a 2017 BRZ that certainly changes things. is it still under warranty? i think you posted this in the wrong forum - this needs to go in the correct Newer Generation forum, maybe more people will see it? Quote Link to comment Share on other sites More sharing options...
impostor Posted December 28, 2017 Share Posted December 28, 2017 I had a customer do this on a 2016 WRX with 600 miles on it. Ended up being cheaper to replace the engine. When he went to start it, it sheared off the key and the timing chain jumped, breaking teeth off the crank sprocket and bending valves on at least both the intake and exhaust sides of the RH head. Hopefully your luck is better. But you're at least un-timing it to replace the woodruff key and possibly the crank sprocket. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 8, 2018 Share Posted January 8, 2018 This is definitely chain cover pull. That sucks. GD Quote Link to comment Share on other sites More sharing options...
Gloyale Posted January 8, 2018 Share Posted January 8, 2018 another reason to avoid gimmicky "performance" parts like "lightweight" pulleys and "cold air" intakes. Subaru spent millions on designing a good dependable design.........why triffle with 2 bit "upgrade" that case more harm than good. Warranty Voided on brand new car + weekender bench racing = dumb Quote Link to comment Share on other sites More sharing options...
mykal Posted January 8, 2018 Author Share Posted January 8, 2018 Thanks for the replies, it's all back together now. It was a chain cover pull as GeneralDisorder said. $120 in parts and a day worth of work. Got the e-force supercharger installed, header, over-pipe, front pipe, exhaust, coilovers, lower rear control arms, new shoes, and it's ready for a tune and final set-up with all my gimmicky performance part. Warranty? hahahaha! Quote Link to comment Share on other sites More sharing options...
MR_Loyale Posted January 12, 2018 Share Posted January 12, 2018 Thanks for the replies, it's all back together now. It was a chain cover pull as GeneralDisorder said. $120 in parts and a day worth of work. Got the e-force supercharger installed, header, over-pipe, front pipe, exhaust, coilovers, lower rear control arms, new shoes, and it's ready for a tune and final set-up with all my gimmicky performance part. Warranty? hahahaha! That's great news. Will you please send me a small cutting of that money tree you have so I can grow my own? 2 Quote Link to comment Share on other sites More sharing options...
mykal Posted March 5, 2018 Author Share Posted March 5, 2018 Quote Link to comment Share on other sites More sharing options...
Cldon Posted July 25, 2020 Share Posted July 25, 2020 I have the same problem but unable to put it back in. How did you manage to put it back? Mine seems to get stuck. I know there’s a alignment. Quote Link to comment Share on other sites More sharing options...
