There's a little known warranty part number for '06+ cars..... SOA635112
You just have to find a dealer that will order it. Or ebay/Amazon it. Technically I think they are supposed to provide a VIN to SOA.... my dealer has sold them to me no questions asked though.
https://www.subarupartsforyou.com/oem-parts/subaru-campaign-wqd40-front-pipe-with-primary-catalytic-converter-vin-required-soa635112
Hilarious anecdote - Subaru calls this the "Pretzel Type" manifold/converter. LOL
Edited by GeneralDisorder
  • Like 1
My Lincoln had rodent chew on the COP harness for one side of the engine, and it was run (enough) before I bought it, like that. After the harness repair and replacing 2 failing COPS later, I noticed raw exhaust fumes at warm idle. I originally suspected a cat problem earlier on, but noticed the 3rd cat was removed, and attributed it to that, seeing as no CEL was coming on. Now a P0420 appears on occasion during light cruising. Kicked the mufflers and it sounds like a rattle can (substrate most likely in muffler). Also, engine is down on power if you try and step on it.
w/o pulling the exhaust, those are *some* things that can trigger a P0420. A vacuum test is helpful assuming obstruction. A visual of the cat substrate (both sides) will tell you if if it's deformed or broken.
