LosDiosDeVerde86 Posted June 23, 2004 Share Posted June 23, 2004 I'm looking to do a lot of stuff to my 96 Legacy and i need to know how interchangeable the parts are from the mid 90's model imprezas and legacys as far as custom parts go. I've seen inside of both and they look almost identicle, but it'd be nice to hear some second or third opinions Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted June 23, 2004 Author Share Posted June 23, 2004 I'm looking to do a lot of stuff to my 96 Legacy and i need to know how interchangeable the parts are from the mid 90's model imprezas and legacys as far as custom parts go. I've seen inside of both and they look almost identicle, but it'd be nice to hear some second or third opinions BTW, the reason i ask is that there seems to be an awful lot of parts available for the imprezas but not many for the legacys Quote Link to comment Share on other sites More sharing options...
Setright Posted June 23, 2004 Share Posted June 23, 2004 Yeah, that's a tricky one. The Imp is essentially a Legacy with a shorter wheel base, but some things are slightly different anyway. Most suspension mods will work, but might require a small amount of customization. Wheels are straight over, and brake componets mount up the same. You will have to take each case separately. I think exhaust is the only area that is a no go, you will need bespoke parts for that. Quote Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted June 23, 2004 Author Share Posted June 23, 2004 Yeah, that's a tricky one. The Imp is essentially a Legacy with a shorter wheel base, but some things are slightly different anyway. Most suspension mods will work, but might require a small amount of customization. Wheels are straight over, and brake componets mount up the same. You will have to take each case separately. I think exhaust is the only area that is a no go, you will need bespoke parts for that. What about engine mods? Quote Link to comment Share on other sites More sharing options...
