95' Legacy won't start in PARK
13 replies to this topic
#1 Bushwick
Bushwick
    1000+ Super USER!
  • 1,337 posts
  • Ohio Akronish
Posted 06 December 2017 - 05:12 PM
Car has been sitting a bit, and initially it started w/o issue. When I pulled it out of Park though, the shifter was extremely tight, so I immediately put it back into park, and there it stayed. I can hear the solenoid clicking when I press the brake pedal and press the shifter button, but it won't leave park and won't start in park. Only way it'll start atm is if I insert something into the upper left hole on the floor shifter cover and put shifter into Neutral.
I did try and run the shifter back and forth a bunch of times and it feels a bit looser, but still won't exit park or start in park. All the gears are matching with indents on the selector, so dunno where to look next?
#2 rocketman
rocketman
    Advanced Member
  • PipPipPip
  • 86 posts
  • fort covington new york
Posted 06 December 2017 - 06:08 PM
My 99 forester does this every couple of months ,l go under the car with wd40 and spray linkage real good.
#3 Bushwick
Bushwick
    1000+ Super USER!
  • 1,337 posts
  • Ohio Akronish
Posted 06 December 2017 - 06:30 PM
You think it's not going fully into park then?
By linkage, you mean the cable? Or a physical arm that the linkage moves?
#4 rocketman
rocketman
    Advanced Member
  • PipPipPip
  • 86 posts
Posted 06 December 2017 - 06:56 PM
I sprayed everything,even took shifter cover off between seats and spray there.
#5 Bushwick
Bushwick
    1000+ Super USER!
  • 1,337 posts
  • Ohio Akronish
Posted 06 December 2017 - 07:04 PM
Cool. I'll have at it and see if that helps. Thanks!
#6 HASx11
HASx11
    Advanced Member
  • PipPipPip
  • 48 posts
  • Waterford, CT
Posted 06 December 2017 - 08:17 PM
Happened with my 95 and my dad's 98 legacy. You have to pull the trim around the shifter and there is a switch that gets sticky on the driver side under the trim you have to clean and manually press it. If you clean it shouldn't be an issue anymore
#7 Bushwick
Bushwick
    1000+ Super USER!
  • 1,337 posts
  • Ohio Akronish
Posted 06 December 2017 - 11:42 PM
You mean under the actual P-R-N-D-2-1 cover, right? I'll check that too then.
#8 HASx11
HASx11
    Advanced Member
  • PipPipPip
  • 48 posts
  • Waterford, CT
Posted 07 December 2017 - 09:36 AM
Yes it gets sticky from drinks being spilled it with the cup holders being where they are
#9 moosens
moosens
    Vintage Subathusiast
  • 1,913 posts
  • Bridgeport CT
Posted 08 December 2017 - 03:57 PM
Coins. There could be a coin down there. Check along the bottom of the shifter with the cover off.
#10 Bushwick
Bushwick
    1000+ Super USER!
  • 1,337 posts
  • Ohio Akronish
Posted 12 December 2017 - 07:18 PM
Well, pulled cover and the solenoid for the lock-out seems to have failed (plunger is loose and doesn't respond). Shifter is moving smoothly now, but still can't get it to start in Park?
The actual shifter appears to be fully seated in the Park gate. The tiny switch on the right-side of the shifter at the base (looks like it has 2 tiny copper arms on it) appears to be working.
Does the failed solenoid double as a start/no start switch?
#11 moosens
moosens
  • 1,913 posts
  • Bridgeport CT
Posted 13 December 2017 - 12:08 AM
One other physical item would be to check the linkage underside. There’s a turnbuckle that can be adjusted for throw. But of course it was working fine up to now. Outside chance something jammed in there. Not much effort to take a peek. Have the wheels chocked.
#12 moosens
moosens
  • 1,913 posts
  • Bridgeport CT
Posted 13 December 2017 - 12:09 AM
Sorry , you said it appears to be seated. I read around that. Lol
#13 Bushwick
Bushwick
    1000+ Super USER!
  • 1,337 posts
  • Ohio Akronish
Posted 13 December 2017 - 02:46 AM
Haven't been under the car. Got a heavy enough snow that I was forced to swap out cars, and the couple times I've had to drive it, I've been putting it neutral to start. Shifter freed back up once it got warm.
Was referring to the gate the roll pin on the shifter stem resides on to lock-out reverse. Whereabouts is the turnbuckle you mentioned? Is it solely linkage (meaning probably rusted up) or is it an arm lever that resides through the trans case?
#14 moosens
moosens
  • 1,913 posts
  • Bridgeport CT
Posted 14 December 2017 - 01:24 AM
On the early Legacys is underside on the passenger side.
