uneven tire wear
10 replies to this topic
#1 whynot
whynot
    Advanced Member
  • PipPipPip
  • 84 posts
  • WA state
Posted 12 December 2017 - 08:36 PM
#2 Bushwick
Bushwick
    1000+ Super USER!
  • 1,337 posts
  • Ohio Akronish
Posted 12 December 2017 - 09:10 PM
Well, uneven tire wear is usually an alignment issue, or something is failing and needs inspected. Take to a place that does free inspections and have them SHOW you what's bad.
#3 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,781 posts
  • Texas
Posted 13 December 2017 - 08:57 AM
TTIWWC
(this thread is wasted without content)
#4 whynot
whynot
    Advanced Member
  • PipPipPip
  • 84 posts
  • WA state
Posted 13 December 2017 - 12:10 PM
took the car in for an alignment. it was out a little, but not enough to wear  tires. They adjusted it back in. Also this is wearing on the pass front tire. it is worn across the tread, not on the edges.
What else do I look at before putting new tires on it
Edited by whynot, 13 December 2017 - 12:12 PM.
#5 1 Lucky Texan
1 Lucky Texan
  • 7,781 posts
  • Texas
Posted 13 December 2017 - 12:51 PM
hmmm, maybe a weak strut is allowing too much bounce. Or, could be a bad tire?
details on car and tires please.
#6 montana tom
montana tom
    Subaru Nut
  • 506 posts
  • trout creek montana
Posted 13 December 2017 - 01:43 PM
I suspect a strut as well
#7 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,667 posts
  • East Coast
Posted 13 December 2017 - 07:51 PM
Strut
But a better description and info would be really helpful.
#8 whynot
whynot
    Advanced Member
  • PipPipPip
  • 84 posts
  • WA state
Posted 13 December 2017 - 08:52 PM
this is a 99 legacy outback wagon. Would that strut  cause tire wear if the alignment is good? I plan on replacing all of the tires, but do not want to have one go bad again on me. The car had new tires on it when I bought it. about 211K miles. They are amerigas tires. never heard of them.
Edited by whynot, 13 December 2017 - 08:52 PM.
#9 matt167
matt167
    Certified Subaru Nut
  • 962 posts
  • Prattsville Ny
Posted 13 December 2017 - 09:02 PM
Toe was probably scrubbing.. Struts will hammer tires and cause flat spots and cupping. Garbage tires will also wear if defective
#10 1 Lucky Texan
1 Lucky Texan
  • 7,781 posts
  • Texas
Posted 14 December 2017 - 08:38 AM
strut and maybe inner tie rod, and crappy tires ????
start from a known good, tight base with decent tires and monitor that corner while doing proper tire rotations. Then deal with w'ever crops up.
that's what we all do with our old cars.
#11 montana tom
montana tom
    Subaru Nut
  • 506 posts
Posted 14 December 2017 - 09:42 AM
Just changed out all 4 struts on a 2001 obw, both right side struts were shot , both right side tires were going bald ... left side struts still held gas and both left tires still had usable tires.   Alignment checked out fine.  Yes, bad struts cause tire bounce and wear out tires.
