yeah, I saw not including tie rods before you capitalised and under lined it but like i said some people refer to the inner tie rods as rack ends, unknown if that include you !
The actual rack shaft length of my PS unit from EA82 is 605mm and has female thread end so EA81 inner tie rods / rack ends wont just thread up to them by mistake on the assembly line as they made EA81 and EA82 same years, dunno if at same plant.
You owe me some hand cleaner for that one :)
  • Like 1
Hahaha, sorry, just wanted to be clear!  It's amazing how easily someone's words or intent can be mistaken when you're reading text.
605 mm, great!  Apparently the EJ racks are too wide and throw off the steering geometry on an EA when installed.  My mission is to find a quicker rack that could be retrofitted to an EA chassis.
605 mm, great!  Apparently the EJ racks are too wide and throw off the steering geometry on an EA when installed.  .
I'd love to see a solution to this as well.
I'm wondering if the EJ inner tie rods are shortened such that Rack+inner tie rod width is identical to the stock EA rack+inner tie rod width - shouldn't that then make them identical in terms of steering response?
Then you just have to shorten the inner tie rods...?
Shortening the steering linkage will effect how the toe changes through the suspension travel. That's what we're talking about, shortened rods has been done but you end up with bump steer.
why is that?  i'm having a hard time picturing it.
seems like the rack just pushes the tie rod in and out the same on both sides - i guess that's not the case?
On flat ground, yes.
But as the suspension travels, the control arm and steering link both move in an arc. If they're not the same length, they will not move in the same arc.
I did a quick google search and found this picture. It's a little oversimplified as it shows those arcs above horizontal, but a cars travel is completely below horizontal. And I would illustrate it with the 2 arcs overlapping at ride height....but the basic property is the same
What about the XT4 rack? It does require fabricating a small bracket and rubber bushing but it's not difficult.
Are they a significantly quicker ratio?
Theyre 30 years old as well.
Last year I had an XT6 rack leaking. Swapped in a used rack - it leaked - got another - it leaked.
Aftermaket rebuilds arent likely OEM quality but are a reasonable option.
Not really any different.  Maybe quicker ratio.  Just as hard to find a good one.
XT 4cyl is literally just an EA82 chassis with a fancy body.
I look for nice 2wd loyales in the wrecking yard.  They ussually have the best chance at being good non-leaking racks as they have not been abused offroading.
But they are all nearly 30 years old now too.
i converted my non power ea rack with a power ej rack and you have to mod it a little but mine works great!
You think it's great.
But in reality, any time you turn or hit a bump your alignment is going wonky.
EJ rack is wider than EA82.  your tires are wearing faster than they need to and I can't imagine it cornering well with toe changing as you move through the turn.
Does any of this change depending on:
1. which model?
2. if it has EA or EJ knuckles (are they offset differently)?
3. lifts
or is the track width difference all chassis - between strut towers?
why are EJ knuckles and axles usable when they're also from a wider track width vehicle?
i think i know the answers but wondering how you guys would answer.
stock knuckles or have you swapped? Edited by idosubaru
The problem, as stated above, is that the EJ rack is wider than an EA rack.  This pushes the inner tie rod pivot point out of alignment with the lower control arm's pivot point.  The problem with that is that when you drive over a bump, the tie rods and control arm don't travel in the same arc.  This difference in travel can introduce a small (or large) amount of steering input that the driver did not ask for, making the car feel darty and hard to trust on bumpy roads at speed.
Using EJ axles doesn't effect steering geometry.  The EJ knuckles don't move the ball joint or strut, so the only real change is the Ackerman angle, due to the relocated steering pickup on the EJ knuckle, relative to the same pickup on the EA knuckles.
Edited by carfreak85
This.
It's about the relative width of the Inner control arm pivot, and the rack.
Small difference might not be super noticeable on smooth roads.....But tires will wear funky over time.
Did this mod once on an 86 EJ22 GL my buddy drove the car for about 2 years and always had handling issues, and weird tire wear.  Swapped out the rack to an EA82 and it is now fine.
ok i have been running my ej power rack in my lifted gl for almost a year with no abnormal tire wear or handling.and we drive a 70 mph speed limit here in Montana.i changed the tie rod ends to ea ones and had to cut the little bracket off the ej rack that held the lines to move the rubber piece that clamps the rack in place.you need to be able to slide it over a bit to make it fit.
im not an expert or am claiming this is the right or best way of doing this.i just did it because it was all i had to work with at the time and it has been working for me just fine.i have kids and am concerned with safety.if i noticed any odd hadling i wouldnt have been driving this for long like.maybe its so small i dont really noyice it,i dont know.but to me it does drive very good.
When using EJ axles, the inner joints are more compressed than on an EJ car. Some people have reported that they bottom out.
Technically using EJ knuckles shortens the tie rod assembly slightly, it's a negligible change when driving straight, but that small change relative to the ball joint really improves the ackermann angle (while turning, the inside wheel turns sharper than the outside).
