2003 Outback Wagon-Engine Trouble-Engine Noise
Good Evening,
I just joined the forum, thank you for having me.
I loaned my 2003 Outback to a friend in need recently.  While he was driving on an exit ramp off the turnpike it broke down.  No warning lights came on before or during the break down.  He could not get it to start back up. Also, he says the dipstick was dry when he checked the oil after the fact.  He put more oil in and towed it back to my place.
Once I got it back to my block, I was able to get it started.  However, it is making a very loud clacking sound once it starts. The engine seems to be running normal with the exception of this sound.  The sound kicks in several seconds after the engine turns over.  I took a video but am having trouble attaching.   A  friend with some mechanical experience thought it might be valve related after hearing it. Any thoughts or suggestions before I take it in.  I don't have a trusted subaru mechanic in New York, my guy is in Virginia and before I tow it there myself I'd appreciate any insight anyone might have.
Thanks!
Ryan
Edited by RycoMoleman
check cam/crank timing. how long since timing belt service.
how much oil was added to bring it up to the proper level? a used engine oil analysis may be helpful if bad rod bearing is suspected.
was there an overheat event? any missing coolant? (look in the radiator-never trust the level in the overflow bottle to accurately reflect the radiator's level))
