84 Power Steering Pump Reseal Kit?
https://www.rockauto.com/en/catalog/subaru,1984,gl,1.8l+h4,1268344,steering,power+steering+repair+kit,416
Looks like rockauto is all out... maybe try searching for the p/n on google?
Edit: ouch. I tried doing an amazon search and the cheapest one was $87. I would recommend checking eBay for cheaper prices, but you probably won’t find much better
Edited by Sapper 157
I went to the section here on 80's Older Stuff, where I posted this, went up into the search button and just typed in ea81 power steering pump.
It mentioned someone who made a kit to use the ea82 set up and it then mounts on the opposite side of the engine.
I thought if it came to me needing that set up I would get it and see about what was needed to get it to work.
I don't like the idea of changing it to the other side but haven't really looked into it. Plus my other idea was finding another pump,
maybe not even Subaru, and custom fabricating something to make it work.
Hope this helps
I did the EA82 pump conversion many years ago. You need a hydro lifter block (EA81T block) or the bolt bosses aren't there. Then you need the crank pulley and water pump for an EA81T. And lastly you will have to have custom power steering lines made up because the EA81T rack is different and so is the cradle that it bolts to. So to use a non turbo rack you need custom lines.
Of course I did it with an SPFI manifold also so there might be clearancd issues with a carb manifold.
That's what I remember from doing it. The board member who owns my old silver wagon lives in Texas and if he sees this he may be able to confirm.
Edited by GeneralDisorder
