Cruise control is not working :(
5 replies to this topic
#1 mattocs
mattocs
    Subaru Legacy Lover
  • 1,312 posts
  • Pittsburgh
Posted 23 June 2004 - 12:21 PM
So yesterday my cruise control stoped working...the light comes on when I press the botton...but it does not let me set a speed or accelarate. Could is be a fuse or something with the brakes (making it think i'm applying the brakes)
1996 Outback...anyone have any ideas?
#2 Hocrest
Hocrest
    Function becomes Fun
  • 1,344 posts
  • Cressona/Pittston
Posted 23 June 2004 - 12:43 PM
4 options---
1st
Look at the trottle, there are two cable to pull it...
One goes through the firewall to the loud pedal, the other goes to a vacum canister in the engine bay, just under the driver's side windshield wiper.
Check out the vacum hose attached to the other side of that canister, make sure it is on tight, mabe use a wire tie/clamp to be sure it is.
2nd
Another issue may be dirty contacts in the switch on the steering wheel, shoot some contact cleaner in there and work the crap out of that switch to clean it out.
3rd
Auto or 5 speed, if 5 speed it could be the switch on the clutch pedal, on one of my old wagons, I had to hold the pedal up with my foot to use the CC.
4th
Could be the brake switch like you said
#3 mattocs
mattocs
    Subaru Legacy Lover
  • 1,312 posts
  • Pittsburgh
Posted 23 June 2004 - 02:56 PM
It was working fine yesterday...then I was in a 35MPH area and wanted to use my CC because cops love to set up speed traps there because if there was no signs you'd think it was a 55MPH...so I was accelerating and setting speed a whole lot with my CC lever...then later...it didn't work.
I'll check out everything and make sure it looks good.
Yes, it is a 5 speed.
#4 mattocs
mattocs
    Subaru Legacy Lover
  • 1,312 posts
  • Pittsburgh
Posted 23 June 2004 - 05:08 PM
I looked at everything and it seemed to be ok. The brakes and clutch come up all the way...so I dunno. Anyone know how much it would cost to get it fixed? I don't know how long I can go without cruise control. :-/
#5 mattocs
mattocs
    Subaru Legacy Lover
  • 1,312 posts
  • Pittsburgh
Posted 24 June 2004 - 11:38 AM
Contact fluid...where could I get that? Radio Shack or something?
#6 Hocrest
Hocrest
  • 1,344 posts
  • Cressona/Pittston
Posted 24 June 2004 - 01:24 PM
RS, other independant electonic shops, Autozone, Napa, etc.
Just make sure it is designed for electronics...
